hawkhkg11
- Aug 28, 2004
Hello everyone,
This question may be asked before so I apologize for my ignorance. There seems to be a hot market for expensive iPod line-out cables lately, but before I take the plunge and buy one, I'm still a little unsure of how they exactly work.
The iPod connector as I've always assumed it, is for a data connection (1s and 0s), but the cables go directly from this to a mini-phono. Obviously with no DAC in between, I assume the iPod connector sends out an analogue signal when it detects that there is no "data connection"? Or does the connector split into a larger portion for digital and a smaller portion for analogue? Furthermore, the point of a line-out cable is to improve sound quality by bypassing the crappy amp inside the iPod. However, it seems like the signal is loud enough to drive low impedance headphones (just that the volume can't be changed). If this is the case, isn't it basically still using the amp, but just at a preset volume that isn't user controllable? I don't understand how plugging another amp into this would lead to a noticeable SQ difference.
Now, in the case of hard to drive stuff, I can understand that a LO cable would be needed to connect to an amp as the iPod at max won't be loud enough for some phones. But for easier to drive phones, is there really a SQ upgrade between a LO cable and plugging in directly?
