OK, so there are bench measure proxies for soundstage.
No, there aren’t. Again, there are fundamental properties of audio signals, FR, levels, etc., many of which can affect our perception of soundstage but you seem stuck on the (false) concept that soundstage is somehow a real thing, some sort of audio property that we don’t or can’t measure, presumably because you perceive soundstage. This concept is incorrect, soundstage not a real thing/audio property, it can’t be measured because it’s an illusion, a manipulation of human perception. The reason that recordings appear to have soundstage is because recordings are created by engineers, who obviously also have human perception, who manipulate various audio properties (using their perception as a reference) in order to create the illusion. We cannot measure an illusion.
One of the claims in this and other threads is that DACs and amplifiers measure so well, there could not be any contribution to in-room performance as it relates to soundstage. Some questions then: 1) how should those measures relate to perceptions of soundstage by listeners specifically? 2) have you experienced any differences in how electronics contribute to how you experience soundstage in your home stereo system(s) when swapping a single piece of electronics ahead of the speakers? 3) if you did, were you able to associate those soundstage differences to specific specifications or bench tests of the equipment in question? or 4) did you experience electronics related differences in how you experienced soundstage in your system that could not be traced back to specifications or bench tests?
1. Those measures do NOT “
relate to perceptions of soundstage by listeners specifically”, so there is no “
how should” they relate! Again, there are just audio properties, that’s it, there is nothing else we can measure when measuring audio. Some of those measures (on their own and in combination) may or may not affect our perception/illusion of soundstage but obviously only if they are of sufficient magnitude to be audible but they do not “
specifically” relate.
2. Yes, of course, some home systems have electronics with different functionality and some of it is deliberately designed to provide options for altering soundstage, for example many AVRs provide algorithmic reverb presets to artificially create the impression of an Arena or other acoustic space. I’m presuming you’re not referring to that type of functionality or to EQ, room correction and other such equipment “
ahead of the speakers” but to straight DACs and amps that are not supposed to be changing the signal? In which case, the answer is “yes” but in specific scenarios, mostly user error scenarios. For example, incorrect gain-staging requiring a very low amp setting which in some cases can cause an audible channel imbalance and possibly/probably a change in soundstage perception. I have also heard such differences with certain tube amps and a NOS DACs but of course these are not covered by the condition of “
not supposed to be changing the signal”.
3. No, I was not always able to associate soundstage differences I perceived with measured differences, quite commonly in fact. However, closer examination of these instances, using a null test, blind test or some other objective determination (depending on the equipment I was changing), always revealed it to be due to perceptual error.
4. Not “
electronics related differences” that couldn’t be traced back to some type of measurement and if you think about it, how could there be? These are electronic devices designed and built by humans for a specific purpose, they are not things we mined, found growing on trees or saw in space, that science has to try to explain what they are, how they work and how to measure them. They are “technology”, our own application of the science we already know, not the application of magic or something else science does not know.
G
