1. You won't If you've got your mind stuck on "big deep bass," that's not what cheap 2.0 setups are good at. What you will get is better imaging, soundstage, and midrange. At the expense of "big deep bass." You'll have to decide what's more important to you. |
I *completely* disagree with that statement, almost with a passion.
The subwoofer is
absolutely not necessary with proper full range speakers. Mind you, you still have a woofer driver, and the cabinet is larger to provide the deep/tight bass that you'll want, but you do not have to have a subwoofer. You will be more than satisfied with a good set of 2.0 speakers, provided you look for speakers that are designed to extend the frequency response. This means a large cabinet, and relatively large drivers, but I am not talking huge here, either.
How much of a difference in quality am I going to have between the best set of 2.1 computer speakers, and the lowest quality ($150 or under) set of studio monitors, and which would be a better choice? |
Alot. And this goes right back to the above issue that I was just describing!!
Put simply, most 2.1 systems, especially cheap ones, should NOT have subwoofers in the first place. Reason being, in order to cut costs, and appeal to consumer image, the drivers used in the satellites are much smaller than they should be, the enclosure is cheap plastic (highly resonant!), and the amplification and crossover circuitry is absolutely horrible.
What happens then, is that the larger subwoofer driver is forced to reproduce the frequencies that the satellites are uncapable of. Even the Monsoon Planarmedia 14 speakers, which aren't bad speakers, have one fatal flaw: The crossover is set EXTREMELY high: 200hz.
In order to achieve decent imaging, the frequency response needs to be relatively smooth, without severe coloration. Placement of the speakers is also an issue. Stereo localization is highly dependent upon midrange, to include bass, down to roughly 80hz and below. What happens is called bass localization, where you are able to "hear" where the subwoofer sits. The high crossover also forces all frequencies sent to the subwoofer to be condensed into mono, thus causing loss of stereo information further, and again, to keep size down, most 2.1 systems don't use very large subwoofer drivers. Some even use drivers as small as 4". COmbined with inadequate enclosure size, and you'll never get deep bass from these so called "subwoofers" to begin with.
That aside, one thing to look out for when buying a speaker is design, cabinet build, and cabinet size. Good solid cabinets will help produce low, deep, tight bass. The goal of a subwoofer is to augment a good, full-range speaker from 20-60hz or so, because that is a very difficult range of sound to reproduce cleanly, and without distortion. A subwoofer alone can easily be just as, or more complex in design than their speaker counterparts (the cabinet that is), and cost just as much.
Also, searching for "studio monitors" might be a bit vague, and may also be redundant. Some speakers are referred to as studio monitors just as an advertising gimmick, and doesn't necessarily mean they will be of decent quality, either.
I would recommend you get a decent set of Floorstanding speakers, if you can, and possibly increase your budget. I would look for at least dual 6" drivers at the least, a single 8", or dual 8" drivers.
BTW, if your curious, here is what I have for speakers (excuse the price
http://store.yahoo.com/discountsonline/adas22sp.html - These are the best speakers for the price I have ever found. Deep solid bass to 35 hz, no joke. Excellent dynamics and imaging. They aren't terribly forward, and are a bit bright though, but sound great out of my Marantz 2230B.
