JiggaD369
- Apr 18, 2005
I need to power a small DAC which has a requirement of 12V power source. I was thinking about replacing the wallwart with a DIY PSU and was intended on building a Gold Reference regulator but then came across the Hiface modding thread and saw the positive feedback of powering small devices with battery power.
So I got to searching and I see that there are loads of rechargeable batteries on Ebay and was wondering how can I use one of them.
Some examples...
http://cgi.ebay.com/DC-12V-2800mAh-Super-Rechargeable-Lithium-ion-Battery-/250745125931?pt=US_Batteries&hash=item3a6192fc2b
http://cgi.ebay.com/ZEUS-12VOLT-7AMP-SEALED-RECHARGEABLE-BATTERY-PC7-12F1-/160532386981?pt=LH_DefaultDomain_0&hash=item256079d4a5
http://cgi.ebay.com/1-pcs-12V-1300mAh-Rechargeable-Battery-Pack-Charger-/130471601169?pt=US_Batteries&hash=item1e60b6a411#ht_2851wt_909
I see that the chargers and the battery output use the same port so the battery has to be disconnected from the unit being power when I have to charge it, correct? OR is there a way I can use a switch to power the DAC and cut the charger and cut the power to the DAC and start the charging?
There are all kinds of batteries (li-ion, lithium, etc)..which one would make the most sense for this purpose? Or does it even matter?
Some examples...
