I need some help fixing my Effect Audio cable. The cable broke right before it enter the 2-pin connector. I tried but could not open up the little connector. Not sure if it is glued or not but just could now figure how to open it up so I can see if I reconnect the cable. Also does it require soldering to reconnect the cable to the connector? Thanks in advance for any help.
How do I fix my Effect Audio Ares II cable?
- Thread starter Ben Vo
