Originally Posted by PhaedrusX /img/forum/go_quote.gif
i'm curious about this, as well. output current specs for amps are helpful, but i wonder about the needs of the headphones themselves.
very low. headphones dont need much current, even low impedance types RARELY take more than a few ma unless you listen LOUD.
The key to all of the "big power" headphone amps is how cleanly they drive the low impedance headphones.
Originally Posted by Gradofan2 /img/forum/go_quote.gif
I'd email Grado labs... and... ask them what the output current is for their RA-1 AC amp, as well as their recommended range of output current.
The chip used in the RA-1 is able to output LOTS of current for an opamp. About 70mA per channel, per the datasheet.
The opamp does not run fully class-a though, so an amp with less output current, but full class-a could (and often will) sound better. The RA-1 does have great synergy with grados though.
Then... I'd email the vendors, or mfrs, of the amps you're considering and find out what the output current is. |
very little in tubevile is this high, but it is all class-A (for headphones anyways), where the ra-1 is class-ab. BIG difference. I think both the extreme and zanadeux come CLOSE, but even a morgan jones with VERY little output current can get a grado going LOUD before it clips.
But... in general... I think you'll find... amps with very low output impedance have more output current than amps with moderate to high output imedance - so you might use output impedance as a "proxy." |
eeeh, this is a decent rule of thumb, but there are stumbling blocks.
It is totally possible to make an amp with a 1 ohm output impedance that cant supply more than 2ma. The output stages of many preamps are constructed this way. My EQ is fully class-A and has a 10 ohm output impedance, but the output stage falls to class AB when driving anything less than about 10K ohms.
