BavariaBarbarian
- Nov 26, 2004
Hi there!
I've recently (finally... ) finished my Pimeta.
(Btw. I like how it sounds quite a lot, and tip my hat to Tangent and the great people here in the DIY-section.)
It runs off a 20V AC Power-adapter regulated by a Tread.
Now I figured it would be convenient to also power my Ipod through the Tread (especially as I've lost the original Ipod-PS on my last holiday-trip).
Now if I hook up the Ipod and switch on just the Tread, not the amp, all's fine: the Ipod lights up and charges.
If I connect just the Ipods lineout, all's well also: I can hear the music play.
However if I connect power and audio, the sond fails. It gets really soft and distorted. - Sounds like a grounding problem, and indeed, I discovered that the Ipod internally connects audio-ground to firewire-ground (and that's also V-).
So signal-ground is suddenly the same as V- of the power supply and while I'm not sure I completely understand what this does to the Pimeta circuit, it sure stops it from working.
Now what can I do to make this work?
Many thanks in advance,
Mat
Mat
