mbriant
- Jun 21, 2001
Could the magnetic field from a loudspeaker erase a MD? Or damage the TOC?
Just wondering.
Just wondering.
Originally posted by mbriant Could the magnetic field from a loudspeaker erase a MD? Or damage the TOC? Just wondering. |
Originally posted by MacDEF Fortunately, that's not possible. MiniDiscs are simply magneto-optical discs -- unless the recording laser is focused directly on a data block, there is no way the polarity of that block can be changed. |
Originally posted by Braver my Sharp MDP won't let you open it when it hasn't finished writing the TOC, very handy feature. |
Originally posted by gloco Very odd stuff going on there Beagle. What the hell is wrong with your gear man? ![]() It really sounds like the TOC are being corrupted when powering down...do you happen to hit STOP then power down? Very odd indeed, i've been using the same deck for over a year, it's never did anything funky at all (crosses fingers and toes) |
Q:Whenever i finish a new recording the songs will play but when i take the minidisc out or when the player turns off and i try to play the disk the BLANKDISK message apears on the screen and the recorded songs wont play. A: You can know if the MD recorded only after the recording was completed, the TOC was written, and you play the recorded material. Time advancing, track marks, and monitoring the sound is indication that some parts of the MD are working fine, they do not indicate that the whole recording system is good. What you see on the display is that signal is received by the MD, converted into digital or directly processed and sent to the recording system. We don’t know if the signal is actually recorded and if it is, we still need to wait for the TOC writing. In some cases data is recorded but the TOC cannot be written. This ends with blank disc. If the recording head is broken we will find that the material was not recorded at all. If it is good but the laser unit is weak (it can still be good for playback) for the recording process which needs 10 times more power then in play mode we end with “disc error”. If part of the disc was recorded before the problem occurred it would be erased, because the TOC area will be destroyed. The material may still be present on the disc but not accessible |
