mgrewe
- Apr 4, 2009
I was thinking about making my own crossfeed filter based off the basic Jan Meier design. http://www.rock-grotto.co.uk/x-feed.htm# But since I'm new here, I'm not really sure if it would make a difference to my CD setup.
I have a headroom total bithead amp that I use with my comp and ipod, and I prefer listening with its crossfeed most of the time. But I don't use the amp when I listen to my cd player because it has a pretty decent hp amp built in. I want to add crossfeed to my cd setup but I'm not sure if I should just plug in my bithead and use that cf, or build the Jan Meier.
Plus, if I were to make my own cf, I would change the RCA in/outputs to a 1/8" jack (input) and a 1/4" plug (output). That way I could plug my headphones into the cf, then the cf into the hp output on the cd player. (Would this hurt sound quality?)
If anyone has thoughts or suggestions that would be awesome. (I also don't have a large checkbook b/c im still in highschool)
Thanks
Thanks
