now i do that too!!! after I lost 50ml of freeprint... on more basic resins also ABS like I use the small heat fan and I can print after shaking and blowing right away...personally I leave rested the resine detax feeeprint at least 30 minutes the time the bubbles rise to the surface and then I launch the printing
Home-Made IEMs
- Thread starter Bilavideo
Aldo40
Member of the Trade: Alambic-Ears
Coolnow i do that too!!! after I lost 50ml of freeprint... on more basic resins also ABS like I use the small heat fan and I can print after shaking and blowing right away...
Dreve materials will turn yellow. Regular Clear will be almost brownish yellow after post-curring and lacquering, we switched the moment Brilliant clear was released. Brilliant clear will turn only just slight yellowish after lacquering, it's not something that's noticeable. I have no experience with Detax yet.Oui c'était décidément du super matos il y a quelques années avec ses inconforts, je trouve l'histoire du changement de bacs naze, c'est vraiment un point faible chez eux:froncer les sourcils2:
Earsonic chez nous ils ont la HA20+ c'est une belle machine, d'ailleurs si tu l'utilises, que pense tu de la résine clear dreve fototec DLP?
Je n'utilise que le moule Detax freeprint pour le moment, mais je trouve qu'il a des reflets violets.
J'utilise le DREVE en traditionnel qui reste parfaitement clair sans reflet de couleur, j'hésite à acheter un litre de fototec DLP.
Si elle a le même visuel que l'S IO, je suis intéressé à avoir des retours.
Merci
Aldo:clin d'œil:
swtnate
Pro3dure IN-R clear is REALLY good too. You just have to ramp the UV exposure And not just a full UV light.Dreve materials will turn yellow. Regular Clear will be almost brownish yellow after post-curring and lacquering, we switched the moment Brilliant clear was released. Brilliant clear will turn only just slight yellowish after lacquering, it's not something that's noticeable. I have no experience with Detax yet.
I haven't received all the materials yet, but I hope the tubes will fit .. look a bit small.
swtnate
They will fit. just be mindful of shell thickness.
Thank you!They will fit. just be mindful of shell thickness.
Resin should be here in couple of days. I will use 3BA drivers.
It’s my first one
musmecca
Got a few Rab 32257's and was thinking of executing some sort of etymotic iem...something different. I read through Dhruv's 4 rab setup which seemed intriguing, but I definitely want the bass present. Can I exicute this with some of my custom shells? Do I need added bass? Ideas appreciated...
swtnate
Depends on the overhead your wanting. If you need a ton, youll need a dual sub or a strong DD. If you dont, the. The 4 RAB’s should be fine. However, if you want the extended high shelf, youll beed to look at the the tweeter as well.Got a few Rab 32257's and was thinking of executing some sort of etymotic iem...something different. I read through Dhruv's 4 rab setup which seemed intriguing, but I definitely want the bass present. Can I exicute this with some of my custom shells? Do I need added bass? Ideas appreciated...
Does anyone know where I can find a tube piece like this?
OK.
I made a pair of HODVTEC 31618 + ED 29689
The 31618 + 15/20/24R and 2 Yellow Dampers generate very powerful bass/subbass but it could also hurt your ears.
I can feel that pulse from 31618 making myself so tired when listening.
When I put a 30R on it with 1 yellow damper the bass reduce but freq after 700hz started mess things up....
Very confusing driver......
mattmatt
- Feb 11, 2012
Hi, for what are you gonna use this for? I haven't seem something similar actually.Does anyone know where I can find a tube piece like this?
I’ve 3 BA drivers to install but only 2 tubes will probably fit into the nozzle.Hi, for what are you gonna use this for? I haven't seem something similar actually.
So I wanted to use one tube for 2 drivers stacked together. I guess stretching the tube with a heat gun and tweezers will do the job.
I will make the shells tomorrow. Still don’t know what tube sizes to use. I’ve ordered 2x3 mm and 1x2 mm tubes.
Yeah when building my Finale 2, I used a heat gun and tweezers to stretch the tube around the whole BA since the drivers for that build don't have spouts.I’ve 3 BA drivers to install but only 2 tubes will probably fit into the nozzle.
I’m using the drivers from the KZ AS06.
I wanted to go the budget way for the first DIY project and no wiring needed.
If the tubes are 100% sealed with the drivers, can I fill the shell‘s with resin?
Looks like the biggest driver has a hole on the back.
Total: 13 (members: 0, guests: 13)
