kkugel
Member of the Trade: IEM Maker
Same Chamber design, same dampers. Pinna peaks so differently, it's really bad. Anyone know a solution? It's a planar so DD knowledge is applicable, it's just way more sensitive
What’s your driver config?Same Chamber design, same dampers. Pinna peaks so differently, it's really bad. Anyone know a solution? It's a planar so DD knowledge is applicable, it's just way more sensitive
I have a 4.5mm ID equivalent tube already lmao, it's undamped@kkugel I couldn't use dampers, too sensitive. But your ID is too small and pushing the peak left, remove damper and increase ID.
Single planarWhat’s your driver config?
ok so only one driver that matches the response curve you posted above. but I don’t understand because you show two curves, one of which has bass and the other one doesn’t.Single planar
Ah sorry, I'm in to deep and forgot to explain: it's 2 earphones of identical buildok so only one driver that matches the response curve you posted above. but I don’t understand because you show two curves, one of which has bass and the other one doesn’t.
donc quel est le problème? sur le deuxième graphique ce sont les basses qui sont atténuées ?ok donc un seul pilote qui correspond à la courbe de réponse que vous avez postée ci-dessus. mais je ne comprends pas parce que vous montrez deux courbes, dont l'une a des basses et l'autre pas.
No, it's the pinna peak I can't shift up in one. It peaking at 1.5khz sounds really baddonc quel est le problème? sur le deuxième graphique ce sont les basses qui sont atténuées ?
ok but I don’t understand why you didn’t have the bass on the second graph.No, it's the pinna peak I can't shift up in one. It peaking at 1.5khz sounds really bad
99 wow, what did you buy?My $99 3D resin printer got here, anyone have some 3D models, stuff like DD to tube adapters, multi BA adapters, shells? Anything really for a test print, googling now.
