swtnate
I know its used and recommended in every DIY forum dedicated to this subject. I too used. I still have it around only as a last ditch effort. That stuff IS SOOOOOO FRUSTRATING. If you boot or wrap your drivers itll get stuck on there, leave residue, require clean-up, etc. you also have to be super mindful to not get it in the sound spout. Which can be difficult as sometimes you need to position the drivers at a certain angle. Switching to soft clamp alligator clips or wrapping the driver in a latex tube then clamping has saved so much frustration, clean-up, etc. when I do use it though, no way I will ever use the blue. I use the white version from gorilla glue. Less prone to super sticking and any residue left behind is indistiguishable.I think the common approach for soldering onto driver pads is to use a putty to hold the drivers in place. The most common one I’ve seen is Blu Tack.
@dhruvmeena96
You mentioned a finale 4 a few years ago and I’m curious if that has any new progress.
I built a finale 2 recently and was wondering if a 38D1XJ would help with the bass. I found an old post that said it would work with a yellow damper but nothing about tube length and damper position.
