Aldo40
Member of the Trade: Alambic-Ears
Hey guys,
I've been reading stuff from this thread for a while now and finally decided to get into making my own IEMs. I’ve taken a lot of time to research this stuff, but it’s still quite hard and I don’t yet understand everything. My plan is to order a IEC711 & impedance curve measurement device from taobao, then use those two measurements of both drivers in VituixCAD to design the electronic crossover. Obviously if I succeed, I will report back with the exact values I used so anyone who wants can copy the design.
I wanted to design a dual driver setup with a similar frequency response to the Etymotic ER3XR, same bass, mids, and upper treble but with slightly less pinna gain (3Khz peak). My idea to achieve this is to use a CI-22955 for bass and mids 20~800Hz and ED-29689 as a full range driver. To not let the CI make the midrange too warm I want to dampen it and use an L-pad, if I understand it correctly this should make the ED treble comparatively lower. To get similar upper treble as the ER3/ER4P on the ED I wanted to use a horn to boost the upper treble, but in combination with the right damper filter so it doesn’t bring up that 5K peak.
My questions are: does this seem achievable with these two drivers and could this design be improved in some way?
I would say that your Lpad should be reviewed because I don’t think the impedance is linear with these values, try 4R7serie and 10R// to begin with, the impedance should be linear. You’ll force the 4R7 if you get too many bass.
For your CI tube I think you can use yellow damper at the end of tube, you can start with a 4700 and added to adjust.
On the ED29689 you can use a green damper in a tube of 1.5mm ID over 10mm long to start.
If you lack extensions or performance on high frequency, you can increase the length of your tube by a few millimetres to adjust but for this it is better to measure at the same time to see the evolution on the response curve
