I spoke with my contact there. They're just out of stock right now. Probably back in a week
Home-Made IEMs
- Thread starter Bilavideo
Farquarl
- Jun 20, 2016
Im working on a low Budget driver combination. Goal is to be under 10 € per pair.
Im using a cheap 6mm dynamic driver 1€/$ and the RAD. The Plan is that the drivers will be put into a custom housing to combine their sound outlets into a single port.
his is what i have done so far. I dont have measurments yet or can tell you what the sound is like. Maybe some of you have some good ideas to further improve this design.
Farquarl
- Jun 20, 2016
I mean it will definitely need some work but for a first try it aint too bad. (No filters no Crossover)
musmecca
That looks great! I take it you 3d printed the housing?I mean it will definitely need some work but for a first try it aint too bad. (No filters no Crossover)
Farquarl
- Jun 20, 2016
Yes exactly i 3D printed it. The low end is still a bit much for my taste, right now they sound like Beats.That looks great! I take it you 3d printed the housing?
mattmatt
- Feb 11, 2012
This looks great. A bit little on the treble for me tho.I mean it will definitely need some work but for a first try it aint too bad. (No filters no Crossover)
dhruvmeena96
Bro, it already looks better than many chifiI mean it will definitely need some work but for a first try it aint too bad. (No filters no Crossover)
i will recommend you to create a leak point, so that you can linearize the bass response(leak bass)
and grey damper to tame the 8 to 9kHz a bit
JEHL
Do I wanna attempt a Tribrid? or are DDs and BAs far cheaper than every other type of driver if low budget is important?
dhruvmeena96
and here i am working on Hexa brid lolDo I wanna attempt a Tribrid? or are DDs and BAs far cheaper than every other type of driver if low budget is important?
bone conduction
DD
planar
BA
EST
peizo
DD and BA are cheapest you can get though
Farquarl
- Jun 20, 2016
What is a peizo?and here i am working on Hexa brid lol
bone conduction
DD
planar
BA
EST
peizo
Piezo electricWhat is a peizo?
jameswalker
Its piezo:
https://en.wikipedia.org/wiki/Loudspeaker#Piezoelectric_speakers
More commonly used as sensors typically:
https://en.wikipedia.org/wiki/Piezoelectric_sensor
JEHL
Seems like I'd be interested in a 1 DD+1 BA+1 Piezo.
Does that sound like a nightmare to tune?
jameswalker
Farquarl
- Jun 20, 2016
There is really no way of telling this with a random dynamic driver without any reference measurment. Do you have a knowles or sonion BA? you could measure it with the tube length and diameter they use and compare it.I am just sanity checking my calibration rig. Does this seem about right for a single dynamic driver IEM? Sweep at -12db, with no reference level set:
