Home-Made IEMs
Oct 6, 2019 at 9:29 PM Post #10,127 of 16,017
What about this meze earphone?
http://imgur.com/gallery/l5U4rrR
I also like that body shape and building another iem inside that shape, this is not engraved, it's like it's painted on it or even another material, very thin, what chamical would wipe this off?
Thanks
_Dave
Why dont you buy custom shell from aliexpress or Taobao....that's gonna fare you better
Shell(metal and mmcx)
https://s.click.aliexpress.com/e/5FTSDRRK
Cable
https://s.click.aliexpress.com/e/KM31SXxE
Drivers
https://s.click.aliexpress.com/e/dYQURHmg
And the tubing structure is on my previous post....
Damper is brown
Dont start disassembling already made earphones...it won't be pocket friendly.
If you want to experiment and want shell which costs less and is easy to work with....just tell us....we all will get you the links and everything.
Oct 7, 2019 at 8:39 AM Post #10,128 of 16,017
Cable
Drivers
Damper is brown
I appreciate you guys, I didn't know how awesome you guys really are.
Well the links provided allready helped out ordered some.
However since I destroyed these. Meze headphones I'd still like to. Experiment further and wipe that logo off.
How do I wipe the logo off the aluminum body, what chemical?
Oct 7, 2019 at 9:03 AM Post #10,129 of 16,017
Is the logo engraved with laser?
Oct 7, 2019 at 9:59 AM Post #10,130 of 16,017
Can anybody make the STL file for this..
RAB-p tube structure
Dont want to adjust tube till I get perfection.... Its an hassle
And I dont know how to do 3D properly...I used to get it done by a friend who recently left the office and is now way too far away and way too much busy
I'll try to take on the quest,
u want it straight? or do u want some bend on the tubing?
u want me to smooth the inner edges of the tube? or just make it as it is?
how thick is wall of the tube?
btw, here's the universal nozzle with integrated tubing & BA mount for MASM 7, i've just made recently, haven't tested it yet.
Made it according to the spec found in this thread,
about 20mm ID 2mm for Bellsing 10013
about 16mm ID 2mm for RAB/RAF
the tubing length might have an error of 0,2 to 0,4mm because of the bend
u can put the filter at the end of the tube as usual(might need a little extra push)
The BA mount should fit with a little room for wiggle, the nozzle might be on the bigger side, 6mm diameter.
U can also use this for BZ6, just plug the RAB hole
SLA printing recomended
And here's the STL if anyone want to try
https://drive.google.com/open?id=1nQTlUpnintGY-TW68qLvotfhfXO7-9gC
NOTES: this is not a correct model of MASM7, will revise and post a new one in a few days. Can still be used as BZ6, plug the third hole
  • nozzle masm 7.zip
Oct 7, 2019 at 10:12 AM Post #10,131 of 16,017
Dammmm bro...
That STL rocks
Thickness of outer wall is your choice...
Somebody might need it till the last 2mm/2.5mm part as they are using universal shells.
And you can smoothen down the inner edges...that will help in reducing diffraction losses and artifacts..
Man, you made the MASM 7 shine.
Error are tolerated till its not crossing over 1.2mm lenght
OK.....I checked it
Why are there three bores.
That might make tuning harder, even though flexible
I used BS6 as independent fullrange
Oct 7, 2019 at 10:42 AM Post #10,132 of 16,017
Dammmm bro...
That STL rocks
OK.....I checked it
Why 3 Bore? Uhh, because i knew nothing :grin:.
Flipping trough this thread, i found someone said to make MASM7, add RAB with the same tubing found on MASM
Seriously, im really new here, the only experiment i've made is BZ6 with half of the tube made into the 3d printed resin shell, exactly follows the tubing schematic :yum:
Oct 7, 2019 at 10:56 AM Post #10,134 of 16,017
OK
Lemme make you understand about MASM 7
BS6 all three spout has to be terminated into one tube which is double damped
Brown near spout, white on center
RAB runs damperless
Which makes it two bore
But still appreciated for your hard work..
For those who have not tried it...
By the way, MASM 7 dynamic levels and Harmonic impression are flagship level...just cannot take it out of my ear.
But still cannot take on the treble resolution of Orignal MASM 3 pro.
The MASM3 pro treble is on different scale altogether for me.
Oct 7, 2019 at 11:11 AM Post #10,135 of 16,017
Oct 7, 2019 at 11:14 AM Post #10,136 of 16,017
OK
RAB runs damperless
Dang, i need to rework the model :laughing:
What's the length of the tube for BS6? is it the same as usual? 20mm?
Oct 7, 2019 at 12:51 PM Post #10,140 of 16,017
