dhruvmeena96
Recent simulated spec
@Choy Wei De
@Ivan TT
@IvanNOON
Single RAB32063
Cz=4.95uF
Rz=38.125ohm resistor
Increase Rz to get more 2kHz peak and treble
Decrease Rz to get less 2kHz peak and treble
This is the golden number for damping a RAB32063 zobel circuit
Now comes tubing.
5mm(length) 3mm(diameter) ID=Near Driver
5mm(length) 2mm(diameter) ID=Middle ground
5mm(length) 4mm(diameter) ID=in Eartip nozzle
MATLAB data tells that it can reach 25kHz easily
Smooth sound
Damm flat impedance
I was wrong about shunting
The Zobel itself makes the EMF peak disappear( a small bump remains, but who cares). @IvanNOON I was wrong about 5kHz.
The C of 4.95uF in conjunction to RAB32063 crosses at 1.5kHz, which make the parallel resistor also affect the impedance of emf peak.
So now shunting will just make that small bump disappear and slightly better phase but loose volume.
@Choy Wei De
@Ivan TT
@IvanNOON
Single RAB32063
Cz=4.95uF
Now comes tubing.
Smooth sound
Damm flat impedance
