Hey, good work guys! The Loctite ResinAid 3596 is perfect! The only problem is I don't think it's available in the retail market. I did a cursory seach of Loctite distributors and couldn't find any that carried it. A few possible avenues to go down: 1) contact Loctite/Henkel and find out if it's available in retail; 2) contact a Loctite distributor and ask specifically if they carry it or could get it for you; 3) reach out to Guiseppe. Maybe he'd be willing to supply us with the materials that he has access to as an audiologist. Also, the Loctite/Henkel website talked about a piece of hardware specific to these products because some of them are UV cured. I assume that hardware isn't "necessary" but it might be worth looking into as well.
The "Pro Float Floatable Ear Protection" material sounds promising. I guess it would depend on how flexible/rigid it is. If it's really soft you'd run into the same problems as you would with the Smooth On Lifecast material, namely the shifting of internal components and degredation over time.
I was also thinking, what about just using acrylic nail polish to pour the entire mold? I don't know how well it would harden through since it's designed to be applied in thin layers. But I think I'm going to pour a test mold with it and see what happens. Even if it takes several days to fully cure, it's readily availble, hard acrylic, and perfectly safe.
