Home-Made IEMs
Feb 6, 2019 at 7:37 AM Post #8,086 of 15,992
How on earth can you fit these into a shell?
well, you are right
metal foil is must
cap has to be higher quality
that is comsol thingie
SILMIC showed least deviation
Nobium cap or good ceramic is lowest point
metal foil resistor is must
ROSE technics use silmic for crossover in BR7
well, highest quality(technical standpoint) so that deviation in spec is minimised
Feb 6, 2019 at 9:29 AM Post #8,087 of 15,992
Here comes the magic
Resistors should be metal foil and caps have to SILMIC II
Impedance is dropped like hell by just simple circuit design.
Zobel and L-pad
Total attenuation is 8dB
Knowles rates the RAB at 108dB, so mine is 100dB
Keeps DC resistance of original but heavily damps the circuit and fixes the impedance and phase. No shift in FR as such.
well, you are right
metal foil is must
OK
tell me what should i use in quality component then
@piotrus-g @Ivan TT @Shilohsjustice @IvanNOON
Feb 6, 2019 at 9:40 AM Post #8,089 of 15,992
No idea
L-pad is series before shunt, why do you have shunt before series?
That is magic bro
Ok if i use the shunt as it is
it drops to 11ohm
if i use series resistance and then a shunt, impedance fix is less noticeable in some part
ok
First signal goes in Zobel, dropping the rising impedance
Then it go into shunt notch parallel resistor, to drop of impedance peak like magic
then a series resistor of highest quality to add back the lost resistance equally to whole impedance graph
Feb 6, 2019 at 9:57 AM Post #8,090 of 15,992
parallel resistor
formula (1/R1) + (1/R2)
so if we take DC resistance 22ohm
and by going about the value of shunt i did
the new value is 11.47826086956 ohm for the driver
on 500 Hz stock impedance is 33 ohm
then the value for driver is 13.89473684210 ohm
on 1kHz stock does a 48ohm(this is Z of a driver)
mine will do a 16ohm
on Resonant peak point, stock does a ~200 ohm
mine does a 21.3ohm
and zobel is making things flat already on HF
Now, adding back the lost resistance according DC resistance(Approx 11.5ohm), we need a resistor which can provide a linear resistance increase
so i added a 10.5ohm in final
so new values are very different from old RAF
Old Stock Values
22ohm DC
33ohm 500Hz
48ohm 1kHz
~200ohm 3kHz
And the rising impedance
New values
22ohm DC
24.4ohm 500Hz
26.5ohm 1kHz
31.8ohm 3kHz
and Flat impedance
the new driver has lost 7.329dB~8dB according to Knowles Pro paper
which gives our driver a total of 100dB ~ 101dB nearby sensitivity on 22ohm compared to stock 108dB 22ohm on stock driver
Then there is some loss on treble side after 7kHz due to zobel working on RAB
so my average is 98dB 22ohm on RAB but with somewhat tamed near neutral impedance
Feb 6, 2019 at 9:59 AM Post #8,091 of 15,992
parallel resistor
mine does a 21.3ohm
Old Stock Values
22ohm DC
33ohm 500Hz
48ohm 1kHz
~200ohm 3kHz
New values
22ohm DC
24.4ohm 500Hz
26.5ohm 1kHz
31.8ohm 3kHz
and Flat impedance
well i did a mistake
Zobel will go inside and reverse L-pad will come outside
Feb 6, 2019 at 10:09 AM Post #8,092 of 15,992
What is your role on stage? In this thread, a few pages back, there is a guitarist very happy with his GK build.
I did not test the GK, but I built a GV and the scary crossover (among others) I did love the GV the most so far. The scary crossover is an intense build, definitively do not start with that.
You should probably follow Benjamins advice, he definitively knows what he's talking about.
Thank you for your input, I will be mostly playing synths and drum machines, so I need to hear the full spectrum as clear as possible.
@koold
GQ-30783 is a good starting point - simple double with 1 sound outlet = only 1 tube to worry about.
White/brown damper for neutral, green/red/orange for bassier sound.
Experiment with 1.5mm/2mm tubing.
2mm*15mm with brown damper (@ end of tube) worked well for me.
If you feel more adventurous try the GQ+RAB build mentioned previously.
I was thinking on going with a 3-way system, I am not that scared of the two tubes... but I don`t feel like messing around with crossovers or many dampers configurations.
I would prefer ordering from mcear than from aliexpress , especially for the shipping times and costumer service in case of any problem, he answered my emails straight away and very kindly, I am placing an order to buy all the stuff neded to make the CIEM there (molds, acrilyc, tubes, cable, etc..)
That´s why I was between this three options, GK-33211-000, GK-31732-000 and GV-32830-000
I mostly inclined to follow his advice to get the GK-33211-000 with no dumpers, but can´t find any info about it, but he told me that it has more bass than the GK-31732-000.
GV sounds good
On stage, you need bass
Do you mean that the GV has enough bass? or that I need extra bass?
Thank you all!!
Feb 6, 2019 at 10:43 AM Post #8,094 of 15,992
Thank you all!!
GQ + RAB is easiest as you are not messing the crossover. Just run them in full range and use the specified dampers
its good in tuning(actually very good detail in air)
Feb 6, 2019 at 10:51 AM Post #8,095 of 15,992
@IvanNOON @eunice @Ivan TT @zern_c @Rabid86
i did reworked the circuit
now
zobel is connected directly to driver
parallel shunt notch is 8.55ohm and 16ohm is in series(Reverse L-pad)
Latest Filter
DC - 22.15 ohm
500Hz - 22.79 ohm
1kHz - 23.25 ohm
3kHz - 24.19 ohm
>5kHz - 22.78 ohm
Old Filter
DC - 22 ohm
500Hz - 24.4 ohm
1kHz - 26.5 ohm
3kHz - 31.8 ohm
>5kHz - 24.4 ohm
Stock
DC - 22 ohm
500Hz - 33 ohm
1kHz - 48 ohm
3kHz - 200 ohm
>5kHz - Rise
Feb 6, 2019 at 10:59 AM Post #8,096 of 15,992
Finally solved the impedance plaguing issue without inductor coil(series notch)
plus resonant peak can be damped on any driver now, which solves the phase issue
For impedance rise, voice coil rise
i need voice coil inductance
but after seeing the knowles data, it is better to use the WBFK or SWFK for tweeter in any purpose. Because the rising impedance is way more flat and can be damped by L-Pad or reverse L-pad(my formula way)
Feb 6, 2019 at 2:50 PM Post #8,097 of 15,992
Well
Go for GQ-30783 and RAB-32257
GQ-30783 => 2.0mm x 19.5mm tubing with a Knowles Green filter (1500ohm) at center of tube + Knowles grey filter (330ohm) after green filter
RAB-32257 => 2.0mm x 15.5mm tubing with Knowles grey filter (330ohm) at center of tube
no crossover required
some soldering required
@Furco design, sounds amazing
If you can get the right fit, in terms of your cIEMs or universals, the sounds is definitely excellent. I still use the pair I built a few years ago today.
Feb 6, 2019 at 7:20 PM Post #8,100 of 15,992
@Rabid86 thanks for testing the design
@Ivan TT I will post the new design today
Rabid86 states that zobel was to powerful in damping the whole spectrum(I still dont know the driver as RAB and RAF peak is on 3kHZ).
Hmm if the zobel is damping so much
That can be due to 41.25ohm resistor
So does any body know if I reduce resistor, how much the change in caps should be
Well he also states that, distortion figures at 1kHz seems more noticeable. I think surrounding distortion was damped so much that distortion seemed obvious at that range.
Lol
