Silverprout
- May 10, 2013
Just noticed that Mike is creator of first hybrid silicone ciem which uses ED and 10mm Dynamic driver.
Awesome !
Wow a really nice looking hybrid! Wouldn't adding another 29689 solve the issue though? Did you limit the dynamic driver to bass frequencies only through the crossover? I'd think the RAB drivers sound nice or Unique Melody wouldn't be using them.
Can get my hands on some GR31587 to try out as some mid range drivers. Hope they sound nice
Did you guys see the Sony custom? Interesting how it uses a Sonion 2356 instead of its own BA drivers
I wouldn't say you are wrong with the design at all. Without test equipment it will be more difficult to see what is going on and how to remedy it but don't give up on it. Make small and listen closely. It's crazy how much a lil tweak here or there can turn a big dip in the highs into a peak on hybrid designs.
Silverprout make yourself a diy measurement stuff. You can easily build one using panasonic mic.
What type of wire are you guys using for wiring the drivers and where to buy it, i cant find anything good to use besides solid magnet wire and that does not make a good joint..??
You can find them in the earbuds cables.
Mine are coming from old AKG K317 earbuds.
You can also use the RG178 Inner conductor (silver and PTFE)
Damn that's neat picture
BTW. looks like fitting MMCX is soooo much easier than 2pin connector.
