Home-Made IEMs
Oct 20, 2014 at 5:09 AM Post #2,236 of 16,051
  I'm thinking of ordering Sonion drivers..
  Still 5 drivers minimum of any type? 20 all together?
  If so, which ones are worth ordering?
  Planning to mix them with Knowles.
Looking for that Sonion-only sound...
http://www.head-fi.org/t/604851/chart-balanced-armature-based-in-ear-monitors-technical-characteristics
See above list and then you can do some research on your own and order.
Oct 20, 2014 at 12:05 PM Post #2,237 of 16,051
Long time lurker,
  Ok so I have been a long time lurker here and gathered a lot of information by reading the entire thread.  What I have not gotten is a solid answer as to where people are getting their UV cured material from.  Can anyone please share a link to a source that can supply in the US?
Thanks
Oct 20, 2014 at 1:06 PM Post #2,239 of 16,051
  Egger, Dreve dont ship to individuals. Egger UV can be found on taobao  but they dont ship due to restrictions from shipping companies.
Some of people here used UV gel used for nails. I am not sure how safe it is for ears.
UV gel used for nails = toxic
Medical grade USP Class VI, ISO 10993-5 and FDA compliance :
http://www.newark.com/loctite/36484/loctite-3921-light-cure-25ml/dp/22M2725
Oct 20, 2014 at 8:33 PM Post #2,240 of 16,051
The item you linked to clearly states hazardous item.
UV gel of any kind is not meant to be applied to your skin or to ingest in its liquid form. Once it is cured, it should be safe and inert, including the nail gel.
Oct 21, 2014 at 2:28 AM Post #2,241 of 16,051
Ultimate ears uses the loctite 3675 in their labs, the 3972 is the same material with the same certifications (a little bit more viscous).
PS : The 3972 is intended for contact with blood
Oct 23, 2014 at 10:43 PM Post #2,243 of 16,051
I am really enjoying my latest build. I changed my single driver design from the SR series driver (decent for the price) over to the ED-29689-000. It reminds me a lot of the etymotics sound but with a bit more life. It is also surprisingly forgiving of lower quality recordings. It is my only build that I can enjoy listening to pandora with because my multi driver IEMS don't like low bit rate audio. I am now very curious to find out if the new RAB drivers can match up to this but it is going to be a while before I experiment again.
Oct 24, 2014 at 3:11 AM Post #2,245 of 16,051
Could you add some photos please ?
