So, this is where I impart some wisdom I've learned to this group in the hopes it makes you better builders and saves some time. I know some will love the idea...some will hate it, but here goes: I HAVE NOT USED MY MIC TO TUNE MY IEMS FOR MY LAST 20 BUILDS......I HAVE BEEN USING MY SOUNDTHIEF. The concept is simple....your ears are used for hearing and most people can discern differences in volume, tone, notching, static, distortion...etc. I assemble my BA's, wire them, put the tubing on, and then use my soundthief to check. The soundthief is simply a long tube with an earpiece on it. I put one end in my ear, and move the open end of the tube to the mouth of the tube I want to check. I check left and right ear at the same time and LISTEN for differences....volume, tone, notching, distortion, etc. I don't have to hook up to a mic....I use my ears. I usually just use a pink noise generator......If they sound identical, which they SHOULD be, I move on to the next set. If they do NOT sound the same, I know EXACTLY where to look. A bad graph says something is wrong, but doesn't show you where.....this does. It also can pinpoint bad glue joints as you move it around the BA...open spots can be heard! It also saves time in assembly as I can quickly isolate something that has come undone. If you have wired in reverse, you can hear a difference as it will sound notched or scooped in comparison to the other. Once a BA is assembled before the face goes on, I can check to see if my treble spout sounds too bright, if my bass spout is too loud or bassy, and I can determine which damper to put in. It can also isolate issues once the IEM is completely assebled as you can hover over each individual spout. Yes it takes some practice, but I was getting very frustrated with my builds. People would make build suggestions on what looked great on a graph and none of them sounded right to me...so I ditched the graph and started listening. Hope this helps.
