maxjsr
My collection is over 10TB of files.............not a benefit to me.
Mine too.....16TB
For installing third party software you can use any Pi4 compatible image as you normally would, just flash to the SD card and away you go, I was running RopieeeXL fine initially before swapping to the RED OS software.How good is the (software) support from Holo? Is there any documentation about installing third-party software?
e.g. Custom DT Blob, Overlays or drivers required.
Is the TF card image available for download anywhere?
S.
BTW.... what is the "USB Redirector" used for ? Thks!For installing third party software you can use any Pi4 compatible image as you normally would, just flash to the SD card and away you go, I was running RopieeeXL fine initially before swapping to the RED OS software.
Though you'll lose access to the USB redirector setting
Used to configure what the USB input does when using the RED as a DDC.BTW.... what is the "USB Redirector" used for ? Thks!
1) No, it's not a DAC, it's a digital only device intended for feeding a DAC, similar to an iFi Neo Stream, Audio-GD DI20HE, Singxer SU-6 etcOk I think I may have misunderstood the RED.
I have some questions though.
1. Does RED convert/process the digital audio to audio/analog - or does it pass the process to USB-OUT, if I use a DDC on this port(USB-OUT)?
2. Can I use it as a streamer with the USB-OUT to a DAC?
This is very cool.Used to configure what the USB input does when using the RED as a DDC.
Can either be set to be a USB 'reclocker'/filter to the USB A output, or set to feed the I2S/AES/SPDIF outs
iFi ZEN STREAM vs RED
Stay updated on iFi audio at their sponsor profile on Head-Fi.
If anyone did I dont think many of them have gone out yet. Pretty sure I ordered within a few hours of it launching on their page and haven't gotten mine yetHas anyone received one ordered through Kitsune yet? Sounds like Covid hit the Holo factory pretty hard, but some who ordered through Wildism have received theirs.
I received a text from DHL this afternoon.That’s my expectation. Tim had said that it would be quite a while. I ordered on the first day too.
