Lavcat
I received my Red today. Set up was easy and sound is good. My issue is I don't know how to specify an IP address in Red OS. Does one need to run a different OS to be able to set an IP address?
Reserve the ip for the reds mac address in your router.I received my Red today. Set up was easy and sound is good. My issue is I don't know how to specify an IP address in Red OS. Does one need to run a different OS to be able to set an IP address?
I believe that you will need to use an OS that gives you full access to Network settings. RedOS does not let you change anything (at least not easily). RedOS is what it is, it is very limited in what you can do with it.Thanks, but that would not solve the underlying problem. The NAS with my music library is on a subnet that does not use DHCP. I want to put the Red on that same subnet. Unless I can find a way to bridge two subnets the Red and the NAS can't see each other.
I have an Auralic Aries G2 streamer and it has been sitting on my audio rack unplugged for over a year. I choose to exclusively use my Red because it sounds better and the user-experience with LMS/Material Skin is one of the best. I am running GentooPlayer on my Red as a Squeezelite endpoint (GentooPlayer does take the user-experience down a notch due to it lacking some Squeezelite settings).I finally put my order in for a Red - now the long waitand wanted to get in before any potential increase in prices. I've been using the Bluesound Node OG for a long time; but wanted to upgrade the streamer. I wanted better sound quality and some flexibility on outputs but didn't want to go totally high-end (Lumin or Aurender or Auralic); but willing to make tradeoff with user experience and my own effort to make it work. I've come to like the Bluesound app and realize i'll need to go to either HQ NAA or Bubbleupnp. I exclusively use Qobuz for source. I haven't decided on HQ and/or Roon but this gives me an upgrade path so I'm excited.
Hi, I‘m looking to get some help for GentooPlayer, my registration is on its way. I want to use JPlay so I guess I should select UpMpdCli - do I need to install it? Do I have to change settings to play from internal Ram? I think the Player is not so easy to set up for a non Raspberry guy like me. Any help and findings more than welcome, looks I can even try different kernel versions.
How did you get it run? I used balena Etcher to format the SDCard to alternative OS. But the Red ist only flashing red light, when i inserted the SDCard.I use Moode since yesterday
Doesn't work for me. I don't know what else to try. LED ist still red.I used Balena, too. Without issues. Than changed settings via MoOde.local
