You can run convolution filters in HQPlayer but they’re not running in Red. They’re running on the machine where you run your HQP server.With the HQPlayer OS (HQPlayer embedded) is it possible to run convolution filter and upsampling on the Red and be visible as Roon endpoint - so using Roon as frontend?
Holo Audio Red Streamer
- Thread starter lsantista
According to Wildism Audio HK's Facebook post, they are waiting for some Roon ready certificate to make it available again.A quick updated for those interested, the 2022.12.28 Red OS image mentioned earlier in this thread will load on my 2401 Red and Roon functionality is there.
update to 2023.03.10 = Roon yes
update to 2023.03.27 = Roon yes
update to 2023.04.15 = Roon yes
...most have followed this thread longer than I have, so you know when the cut off happens.
Ropieee 2024.1.1 for the Raspberry Pi 4 and Compute Module 4 also installs and Roon functionality is there as expected.
https://www.facebook.com/wildismaudiohk/posts/803144395159399
gk2013
- Oct 26, 2015
Nothing in terms of hardware, according to Wildism Audio. However, I've tried the new image on my RED and although it does boot up, it doesn't work. I wonder why.
Seems like Wildism is not right. If there was no hardware change all images should run on all Red's.
The post was from Dezember - hopefully we will see any progress soon
There must be a hardware difference. Otherwise, I don't see why 1) they would get certification from roon based on serial numbers; and 2) the devices would act differently with each software versions. I've asked Jos @ Magna, but the reply was not very helpful. I guess we'll have to wait until roon certification process is complete and then we will know for sure.
jcn3
Remember that Roon can play to endpoints running Squeezelite - it's a good solution for the Red for now. Many think that Squeezelite sound better than Roon Bridge.
gk2013
- Oct 26, 2015
Nice, I didn’t think of this option!Remember that Roon can play to endpoints running Squeezelite - it's a good solution for the Red for now. Many think that Squeezelite sound better than Roon Bridge.
You can also download Ropieee, or if you want something better use Gentoo Player!
jconde
- Aug 29, 2005
Please. Can you say a little more about Gentoo. I have used Ropiee before but never heard of Gentoo. What makes it better?Nice, I didn’t think of this option!
Isn’t it possible to use Roon with
Os Release | 2023.09.10 |
just want to know Red DDC i2s whether it can support dsd1024 now?
Manual menton that i2s can support dsd512 only
What would be the easiest way to make it work with Roon ?
jconde
- Aug 29, 2005
I just installed Ropiee and everything works fineWhat would be the easiest way to make it work with Roon ?
How difficult is it to setup and optimize settings for audio quality? Is there a recommended guide?I just installed Ropiee and everything works fine
jconde
- Aug 29, 2005
go to the the ropiee website. Download the binaries. They have a manual. Download Balena Etcher and use it to install the files to a 16gb or greater SD card. Plug it into the back of the Holo Red and Presto! If you are trying to use Roon; this is the easiest way to go.How difficult is it to setup and optimize settings for audio quality? Is there a recommended guide?
jcn3
you can set the red to use squeezelite and enable squeezebox support in roon.
