Info on Red Nano Fuse type used in KTE May model:
Single crystal nano fuse
Specification: 5X20mm @2A(220v) or 4A(110v)
Withstand voltage: 250V (T) slow speed
Features: This product is complicated in process, special materials can not be made, this fuse is 100% pure handmade!
Tip: Input in different directions, the tone is different. Can try different directions
This fuse structure is relatively complicated, it is handmade, so the cost is not cheap, the structure is crimped, the contacts are firm and reliable, plated 24K gold, non-chemical gold. The fuse is made of imported single crystal silver-copper alloy. After nano-processing, note that the fuse is directional after nano-processing. The inner filling of the quartz sand is filled with nano-graphite, and the graphite has ultra-high conductivity and high anti-interference characteristics. The sound is beautiful, soothing and strong in layering. This is the flagship
product of high-end fuses so far.
Fill the fuse with 2 heads of quartz sand for good shock absorption and arc extinguishing. In the middle is graphene, which has the advantages of ultra-high conductivity and anti-interference. The fuse is a single crystal silver-copper alloy containing 10% precious metal, treated with nanographene, and stranded with a single crystal silver.
The fuse cap is stamped from 99.99% 4N copper, one end is plated with 24K gold and one end is plated with sterling silver. Increasing the conductivity and the speed of the power supply make the fuse and the socket highly accessible.
The fuse is firmly pressed by a large one and two small caps made of 4N copper. This process protects the fuse in the middle of the fuse. The fuse and the cap are in good contact and the contact is firm, which can prevent the microphone effect. Reduce the oscillation of current passing, making the sound quality more pure and the image more stable.
The inside is filled with two quartz sands, and the middle is filled with nano graphene. Graphite has super high conductivity, high anti-interference and other characteristics, and the sound is beautiful, soothing and strong. It has great benefits for sound quality and security, but it can only be handmade.
The ceramic tube has anti-resonance and eliminates the effect of the microphone sound.
The fuse is made of a single crystal silver-copper alloy, and a very fine single crystal silver wire is wound to correct the sound. After nano-treatment, it has excellent two-end extension, transient response, dynamic and musical sense.
Fuse Type for L1 and L2 May :
Shurter Gold fuse type
2A SB 5x20mm (220v) and 4A SB 5x20mm (110V)
May’s input and output interface:
- Digital input interface includes
- Enhanced USB (ground isolation) + Titanis 2.0 circuit + KYCON industrial High retention USB Connector (improved impedance spec) – Proprietary inhouse firmware w/ ultra low latency performance. Ultra low noise voltage regulation
- RCA coaxial
- BNC coaxial
- AES/EBU
- optical fiber/Toslink
- I2S (HDMI) – improved ultra high performance 4way custom circuit (NOT traditional LVDS chip anymore) backwards compatible
- I2S-2 (HDMI) – improved ultra high performance 4way custom circuit (NOT traditional LVDS chip anymore) backwards compatible
- All digital input interface supports DSD (DOP mode).
- Analog Output interface: single-ended, balanced.
