ClicketEKlack
Stradivarius is out of the violin biz -- hard pass!!
I doubt my ears have twenty years left. I have a Sony tuner/amp that’s a good 25 years old and works as well as it did the day I bought it, so I’d hope that a solid state DAC should last a while.This violin can last for hundreds of years. Do you think your DAC will last that long?
I think 3 Orea 8lb version will work for each unit.Does anyone know the weight of the dac and power supply, as separate units?
I want to buy isoacoustic feet for each.
Thanks.
It is important to keep DAC and PS units separate. Do not stack them. Both the sound and DAC unit cooling will benefit.
The sound-absorbing/sound isolation measures are not needed and not desired. The original feet work really well; the whole DAC has been tuned to perfection in the factory to work & sound great with its original feet.
The latest May models come with an "upgraded" USB module; one that does not have an XMOS chip but uses an additional combination of ICs to provide the same functionality. What they did is as follows:
XMOS IC = {ALTERA max II + ALTERA max II + ARM Cortex processor + USB Host IC}
Well, whoever worked with digital audio PCB design will know why 4 switching IC's, on such a limited ground-fill area, will sound vastly inferior to only one IC.
... as such, to me (extensive A/B comparison of old vs. new USB module + fair knowledge & experience in digital and analog electronics) the new USB module sounds vastly inferior to the original one. It ruins May DAC potential (which is unprecedented at the moment in the whole digital audio reproduction industry, worldwide).
If you can still get the old USB module - get it! May will sound extended, natural, specious... beautiful. The new module makes the sound cold, 2 dimensional, unnatural and fatiguing... same as the plethora of cheap 1000 - 2000 bucks DACs that get rave reviews on audio science review website, for example.
Even better, get both modules; DO NOT return the original module, and then do A/B for yourself....
Interesting observation and completely contradicts what I have seen in reviews.
Hmmm.... but the May reviews of late are reporting issues. Mostly listening fatigue and need to burn in for a very long time (to force your brain to accept the sound and the new "Enhanced" USB module). All reviews of late are reporting some form of dissatisfaction with the sound.
Check the few years old reports; they state that the sound doesn't change much with the burn-in and that the sound is really nice and pleasing straight out of the box.
