bgpaladin
- Oct 6, 2010
I've just built my first CMOY and am having trouble punching holes in an Altoids can to house it. I tried a steel hole punch and hammer, but the result was a bit messy. I bought a rotary hole punch on Ebay, but it is absolutely hopeless - no where near enough pressure to punch a hole in anything other than paper, cardboard or thin leather. Also, the max hole size is 5mm, but I need 6mm.
Can anyone recommend a suitable hole punch? I'm in Melbourne, Australia, so if anyone knows of a local supplier, I'd be very grateful. I tried Bunnings, but they have only one model and it looks much the same as my "Ebay special". It also only goes up to 5mm.
Thanks.
Thanks.
