Originally Posted by mnhnhyouh
I will only believe properly conducted tests.
I have been looking for data on burn-in, and have found *none*.
I think it is an easily tested hypothesis, and the lack of data presented by its proponents surprises me.
I'm sorry that you have had such problems finding data. It may be that most people can personally discern a "burn in" effect so simply...don't go through the trouble of measuring what they have personally experienced in real life.
Sometimes things just work out that way. "Why write...when I
know??" I'm sure teachers the world over know what that is like. Humans can be lazy when they can get away with it.
It also does not make sense of a professional, published reviewer to go through all the effort of testing a non-burned in product when he knows/suspects it will change after the burn-in; that is what people want to know, the "maximum" performance, or at least what they, also, can expect personally themselves. A non-burned in product only stays non-burned in for a short time and therefore does not represent the goods you will actually live with once you purchase the product, for the life of the product.
Like I said, hard scientific data is the only thing that will help assure the hard-core naysayers.
You have never experienced burn-in personally? Buy a new pair of cans, listen for all of 2 minutes, put them down, burn in for 5 days...come back. Different sound, "quite" different yet still the same cans. I did that with my new 404's and boy, did they change after 300 hours! (300 hours?! Yeah, they're "slow"
). I only listened to them in 40 second intervals until that point and the differences were apparent, so I don't think "mental" burn in happens after 40 seconds! (I didn't have the time during the burn-in to listen longer, anyway. Too busy then).
Audioholics had a burn in test
http://www.audioholics.com/techtips/...kerBreakIn.php
where they do note, pretty much, exactly what we have talked about -
Following initial burn in, suspension compliance would show the usual expected shift, then eventually drift back to and settle at a value something on the order of ~5% to 10% greater than than that measured pre-burn in. In this case, taking the time to burn in drivers was necessary. |
Exactly the range of engineering elastic deformation that was quoted - someplace within 10%.
But that test only did frequency response and did not test transient or other responses. Shame. You would think that a more compliant driver would respond easier to a transient, and that would show up in a test.
