DrBenway
- Jan 30, 2007
A great player; listening to my Clip+ 8GB right now. Picked it up about a month or so ago for the ridiculous price of $65; I think it came to less than $70 with tax.
Pros:
Great sound (I'm currently using it unamped with ProtaPros)
Great format support, including Ogg, Flac, Secure WMA, MP3 (Duh!), others
Has serviceable FM radio with good auto-preset function
Very easy-to-navigate interface
MicroSDHC slot, which makes Flac practical.
Both MSC and MTP compatible
Bright, legible display (text only)
Very small
Cons:
Very small. As in I've lost two of them. But then again, if my head weren't attached to my neck, I'm sure I would have lost that by now, too.
FM reception is good in strong signal areas, but not great. Reception not as good in weak signal areas.
No Rockbox support...yet
Has a clock, but there is no convenient way to display it. You have to drill down into the systems settings menu to read the time. This is because the clock is included, I suspect, for some internal use, and not as a convenience. This is a VERY minor criticism, which could easily be fixed with a firmware update. Not a priority for me, though.
Originally Posted by Hybrys /img/forum/go_quote.gif Sansa Clip/Clip+/Fuze - Cheap, excellent quality, FLAC support, various colors, and external memory. No real quality difference in the series. Cheapest by far. |
Pros:
Very small
Cons:
