I just received a set of Lessloss c-marc 1m rca Entropic process interconnects and a 5m length of DHLabs Reunion Cat8 ethernet, ordered through the Cable Co. took a few weeks for Lessloss to send them the cables, and then 3 days FedExto get to me thereafter.
i have the Lessloss rca in between my Wavelight dac and Zahl HM1. it replaces a length of lower tier Atlas Audio rca interconnects. first thing that hits me is the uptick in clarity and cleanliness up top. vocals are slightly forward compared to the Atlas cables. there is audibly less bass, but i get a lot more information from the low end notes, in terms of texture and details; the low end is definitely cleaned up a fair bit at the expense of some oomph. there is slightly less punchiness too. will run in it for a few weeks and see how it goes.
i've read a lot of good reviews on the Reunion ethernet. decided to give it a go, since i needed a longer length of cable, and the price was right. the Reunion Cat8 went between the Melco S100/2 and Innuos Phoenix NET. the Reunion ethernet is not a very flexible cable, rather stiff, and doesnt really want to bend as i want it to. i'd rate it 8/10 stiffness. i was fairly surprised on first listen, as it immediately felt like there was a lot more low end, to the point of some boominess and bleed into the mids. i was thinking this could well be the most amount of bass i've heard from the Abyss so far. caveat is i didn't get much listening done with the new cable in place, so i am just reporting my very initial impressions. hoping to test and compare a bit more over the coming days.
