TheGame21x
Please say that they are better sounding than your GR07BE.![]()
Sadly, no they aren't. But then again, very few IEMs I've heard are better than my GR07 BE, if that's any consolation.
Sadly, no they aren't. But then again, very few IEMs I've heard are better than my GR07 BE, if that's any consolation.![]()
They are a sweet deal ain't they? If not for the sibilance, they'd be damn near perfect. Sadly...
GR07BE is one the IEMs I hate most for its sibilance. I just can not appreciate the sound because of that crazy sibilance.
Ok, my RE-300a have finally arrived. They sound as if you took RE-400, replaced the filter with the RE-272 one (which it seems to be identical to - same nylon grid), removed horn effect, dampened the driver some more - which is all good. And added a bass resonator around 200 Hz, which is not. I bet that the bass is boosted using the back vent and internal resonant chamber.
Generally highs are similar to RE-400 with actually less dark signature thanks to the filter mod, and evener thanks to reduced horn. Bass is way boosted, >6 dB, but those unafraid to use equalizer will be very well served.
These gain a lot given a good amplifier too. Off of the ancient phone itself, they get even bassier, much less controlled, "mushy". I suspect these issues are even more pronounced in RE-300h given the low impedance.
Out of the new FiiO E18 (review later) and my Lynx Hilo they're gorgeous, in fact I'd dare say better than RE-400 and RE-600.
The driver definitely is the same, it shares a bit of that "zigzag" signature which is specific to the series, but is apparently much more dampened - sacrificing highs loudness a bit more still than RE-600.
They're extremely resolving. Very much on par with modded RE-400, I'd dare say, even can come toe to toe with my HE-6 (de-etched with high end eq and some ). Without equalization they give huge "black metal cellar" feel due to darkish signature combined with bass boost.
I'll provide the EQ curves soon. (Low precision and high precision ones.)
Timbre is cleaner than all of the previous RE series with exception of RE-262/272 - no audible metallic resonance or any kind of plasticky timbre (as in RE0 of old). Bass decay is excellent.
Width resolution is better than the previous models, as is depth, even though just slightly. Though again, without eq you get the "cellar" effect, flatness and overly close presentation. I'd say very similar to being on stage without good monitors, speakers facing the other way around.
Channel balance is excellent - Hifiman didn't skimp on QC in this pair.
I recommend over the ear wear with relatively deep insertion (slightly deeper than RE-400), while using large biflange RE series tips, sadly not included with these. But then, the extra tip set is $10. Great seal is a must, otherwise you will get shrill treble while cutting bass.
Standard wear is also possible, but the asymmetric shell can make one or the other position more comfortable. For me, over the ear it is.
Ergonomics are excellent - but the sore lack of tips, especially larger ones, is troubling. The included tips are small biflange tips and medium cylindrical single flange. Same nozzle shape as in previous models, 4mm diameter, so Comply T200 should fit and if you try hard enough, Sony and VSonic 3.5mm tips as well.
Cable is finally made out of polyurethane, not some weird hardening silicone/kevlar/whatever and looks sturdy - we'll see if it actually is. Does not tangle or kink easily. Sliding cable cinch is not present unfortunately, but the shirt clip is included.
Microphonics are ok with either style of wear, generally not unpleasant, as they're low-frequency.
Shell seems to have been lacquered to achieve smoothness - the texture of the tip end suggests ABS to my fingers, but I might be wrong there. Mold is high quality - the injection mark is visible, but hides under the tip.
No tactile mark of Left/Right channel, but it shouldn't be necessary due to the microphone, which is placed on the left channel
Unfortunately, my ancient Android phone doesn't recognize the new style button control (the other new one does) - I couldn't test that as the shop had the iPhone version - but the microphone works well and with good quality.
Isolation is medium, worse somewhat than RE-400/RE-600, probably due to much more venting. The almost 1 mm, paper filtered vent is located behind the strain relief and is very unlikely to be obstructed by accident.
Yes, call it terribly muddy and all. I actually have RE-400, RE-600 and HE-6 and some more non-Hifiman headphones for comparison. Maybe next you'll call my HE-6 with FocusPad-A terribly muddy too. It was bit muddy off the uncontrolled LG GT540 out, which is somewhat a fail on Hifiman side, that the headphone designed for portable use needs an actual good amplifier to shine. Some of the FiiO ones are good enough for it, as is Leckerton and probably a bunch of other amplifiers with low output impedance.
Giving the exactly wrong tips (sleeves) for it is not quite the best of moves either.
It's not muddy at all given proper source and I have a few of those.. It's super dark and bassy. It's like you took RE-400 and applied hard bass boost onto it after fixing some of the flaws. Yes, it's technically actually a slight bit better than RE-400 and its twin brother RE-600. The bass decay is actually even once you equalize it, no bleed or one note bass in this one. Highs are even more refined than RE-400, on par with RE-600. I'd bet one salary in that the driver is an evolution of RE-{4,6}00 one with even more damping - the shell is only vastly different. Even the resonances match - they're only a bit frequency shifted down and correspondingly wider.
Have a rough equalization curve. I'll be more precise later.
Let's kick this thread back into action, shall we? I just received my pair of RE300h IEMs, and first impressions are pretty promising. They're a lot more balanced than I had previously expected, having already read Twister's impressions. I do agree with them having too much upper bass, but the midrange honestly seems pretty fine. The treble is a little laid back and not very extended, so my impressions seem to be lining up with the ones I am reading here. I'll probably get working on a review while these burn in.
