- Oct 31, 2008
Just read your M6 pro review and you're definitely less enthusiastic, I mean waaaaaay less, than what you are for RE00.
I had a sennheiser IE8, if I remember correctly, and I found it bass-heavy, while I simply loved a pair of PL-50 that I lost (damn it!), so maybe the 00 are a good bet for me, agree?
ahhhh. yep you said the magic words, if you found the PL-50 great then id wager you will be perfectly happy with the 00 bass levels in which case then the 00 is much the better sounding. bare in mind though, youll need a case and youll need to baby them as they are not the most rubustly constructed things compared with the M6pro.
but.... the 00 sound unimaginably good for the money.
