Burn-in with sisters...
Ooooo! I have the he1000 unveiled in for testing and love them! Can you compare them between the Arya unveilied?Burn-in with sisters...
If the Arya Unveild would be less sharp in the high tones, as the Organic, would be an interesting choice.
The drivers on Arya Unveiled, are they also not covered as on the A_Susvara Unveiled?
The seller in the store, told me to not touch the sides on the Susvara, because the drivers are not protected with anything.
Would you say the HE1000 Unveiled are better suited for Classical, Jazz and Orchestra/Soundtrack type music? I have the HE1000 Stealth V2 which to me are a good "All Rounder" type HP that can even deliver the goods on Classic Rock, Pop, Hard Rock and Metal genres. That's my only concern with the HEK Unveiled. I wonder if it will have the Slam and Impact and visceral Bass in some instances for the Heavier music genres like the HEK Stealth does?First impressions of the HE1000 Unveiled.
The listening sessions were done using a Notebook with Daphile, Metrum Onyx DAC3, Niimbus US5 Pro amplifier. The wiring, both power and signal, is Duelund. The headphone cable is the Pure Litz by Playstereo.
The comparisons were made with the HE1000 Stealth which, in my opinion, at its price, is truly a gem.
The first impression I had from the Unveiled version is that of an even more sculpted and transparent sound without losing the naturalness that distinguishes the top of the Hifiman range .
The acoustic instruments and voices are very beautiful, very close to those heard live, the dynamics are explosive and limited only by the power made available by the amplifier.
Compared to its Stealth sister, the soundstage seems slightly advanced towards the listener while always maintaining a good width.
Here are three of the discs I used to compile these impressions of mine.
I listen mostly to classical, opera and jazz. However, I also enjoy some good old-fashioned rock. I can assure you that the HE1000 Unveiled lacks nothing in terms of speed and slam. The deep bass is well present and never rubbery. It is certainly an upgrade over the HE1000 Stealth but, obviously, the HE1000 Unveiled needs to be put in a position to bring out its considerable capabilities. This means that the entire setup must be of adequate quality in relation to the headphones.Would you say the HE1000 Unveiled are better suited for Classical, Jazz and Orchestra/Soundtrack type music? I have the HE1000 Stealth V2 which to me are a good "All Rounder" type HP that can even deliver the goods on Classic Rock, Pop, Hard Rock and Metal genres. That's my only concern with the HEK Unveiled. I wonder if it will have the Slam and Impact and visceral Bass in some instances for the Heavier music genres like the HEK Stealth does?
PS- I tried the Arya Unveiled back in November. Good HP... but I still preferred the HE1000 Stealth V2 over them
What is your Audio chain if I make ask? I couldn't make out what type amp you have in that picture above.I listen mostly to classical, opera and jazz. However, I also enjoy some good old-fashioned rock. I can assure you that the HE1000 Unveiled lacks nothing in terms of speed and slam. The deep bass is well present and never rubbery. It is certainly an upgrade over the HE1000 Stealth but, obviously, the HE1000 Unveiled needs to be put in a position to bring out its considerable capabilities. This means that the entire setup must be of adequate quality in relation to the headphones.
Before heading to the store yesterday, Have owned Utopia 2022 and LCD 5 and hesitate to get another HE1000 unveiled. Yesterday I Took a listen for 3 hours for both unveiled and se versions. If you don't have previous versions before, Yes, unveiled version to me is worth getting even I have both Utopia 2022 and LCD5. Unveiled version is a big step up from se, and sound unique to my other 2 flagships. It is easier to drive, bigger soundstage than se. Can't find other similar sounding planar headphones currently. But If you have previous se versions before and have a powerful amp, to my ears no need to upgrade.Would you say the HE1000 Unveiled are better suited for Classical, Jazz and Orchestra/Soundtrack type music? I have the HE1000 Stealth V2 which to me are a good "All Rounder" type HP that can even deliver the goods on Classic Rock, Pop, Hard Rock and Metal genres. That's my only concern with the HEK Unveiled. I wonder if it will have the Slam and Impact and visceral Bass in some instances for the Heavier music genres like the HEK Stealth does?
Very helpful. Thank you.First impressions of the HE1000 Unveiled.
