Hello all,
I just bought an Arya Stealth off Amazon as an upgrade from my Thie Audio Wraith, and....... I can't tell if I'm doing something wrong, they're broken, or they just sound like this. If it's the last one, they're getting returned.
I'll be blunt: for most sounds, they are bad. I've had $100 headphones that sounded better across the board. Voices are just plain terrible, especially for TV shows, videos, etc. It sounds like I'm listening to people speak from the other side of a wall or through the floor. Honestly, the $15 generic earbuds I have for my phone sound better for voices. Trebles are just awful, all muddled and sounding like soft static. Mids are practically non-existent. The full bass I read these things had also doesn't exist. Strings are always whisper quiet, no matter the volume. However, for the opening three seconds of one and only one particular song, they produce a rich sound, which immediately disappears afterwards. This leads me to think that maybe I'm doing something wrong.
I'm using them with a dual 3.5mm to single 4.4mm cable, connected to a 4.4mm to 3.5mm adapter, and then plugged straight into the 3.5mm jack on my laptop. Maybe they don't produce good sound without an amp? But, I would think they'd sound good without an amp and great with one if this was a lack-of-amp problem. Moreover, I would think an amp would simply boost sound levels, not improve the crappy audio. Crappy audio will be crappy no matter how loud it is.
The Wraith sounded great without an amp. The only reason I stopped using them was the ****ing 2.5mm plugs kept breaking off inside the headphones. I'm seriously considering going back. At $450, they were way cheaper, sounded way better, and felt better constructed.
Looking for advice on the matter. People keep going on about how good they are, but as far as I can tell they're just plain bad.
