This is the second time that I've seen you mention that sibilance is the result of time alignment issues in speakers. Would you mind posting a reference that substantiates that?
I'm on slow arse mobile tethering right now and Head-Fi is the only site that works, but what I'm saying is that if you're not hearing every driver in sync, you'll mess it all up. In any case, it will not be referred to as "sibilance" in actual engineering journals, because the problem is that in car audio forums, people hear that rought "SSSSS" or "TZZZZZZT!!!!" and call it sibilance, thinking it's the same thing as having a spike in the upper midrange and treble, and then they end up wondering why EQ barely works (and if it does, it screws up a lot of something else), precisely because the response isn't the problem. Some cars can measure relatively smoothly with a test tone and then screw up actual music - the thing is, with a test tone, you hear a constant sound, so you don't notice anything out of sync.
One easy way to test this is to go to an IASCA or EMMA event (depending on where you are), and check out the cars that aren't designed to have the subwoofers blow the glass off the car. Listen to them with the Time Alignment DSP disabled, then enabled, then disable it again, in the middle of your test tracks.
If you can't get to these, you can simulate this problem at home. Get some speakers and set them up nearfield at a corner table with no acoustic treatments, and no angled mounts nor angled front baffles on the speakers, and point them at each other like in most cars, and sit closer to one speaker.
And the second time the McLaren F1 is referenced in relation to time alignment. Now that's one I doubt many will understand or identify with. Care to elaborate? On either?
OK...pics can't upload. But imagine these.
Home audio set up, speakers : Chair and speakers form an isosceles or equilateral triangle with the chair at the apex; tweeters and midwoofers are right on top of each other in each speaker cabinet.
Home audio set up, headphones : Each headphone driver is equidistant to each ear as they sit on your head (unless you have a lopsided hydrocephalic head that is)
Car audio set-ups
British - listener's chair (driver)
on right; driver side tweeter at shoulder level to his
right; driver side midwoofer at ankle level to his
right; passenger side tweeter waaaaaay off to his
left, shoulder level; passenger side midwoofer waaaaaaaay off to his
left, ankle level
US - listener's chair (driver) on
left; driver side tweeter at shoulder level to his
left; driver side midwoofer at ankle level to his
right, shoulder level; passenger side midwoofer waaaaaaaay off to his
right, ankle level
Maclaren F1 : Driver at center, equidistant to where you can mount tweeters and midwoofers (almost like being at home!), but most units had no stereo on account of the very expensive BMW "sound system" located behind the driver loudly and proudly going, "VRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR_tgsssshhhh!!_WHHRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR_tgssshhhhh!!!_WHHRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR_urrrrrrm-urrrrrrm-urrrrrrmmmmmm_VRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR_tghshhhhhh!!!_WHHRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR_tgshhhh!!!_WHHHRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR_urrrrrrrmmmmmmm-urrrrrmrmmmmmmm_WWHHHHHHHRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR...."
In a nutshell - you don't typically get time alignment-related sibiance in anything but a car or a badly set up home audio system because you are sitting equidistant to each speaker. At worst, you'd have a desktop speaker that isn't angled but set low on the desk, or you sit too close to 3-way towers, which can be made worse by having reflective walls too close, but still not as bad as in a car.
You can have a Mclaren F1 because that one has a center seat for the driver, but then again, why buy a car like that to put a sound system in when BMW already provided a V12 bested only by the 5.4L Ferrari V12 and Lamborghini 5.5L V12 when it comes to smoothness at low speed while still providing dramatic, Le Mans kind of sound at full tilt? Not to mention the F1 barely has any sound deadening compared to a Camry, much less a Ferrari 456GT, so even if you put in an audio system, most of the time the V12 will just drown that out (unless you mostly drive the F1 in traffic).
