kreangsakkan
- Jul 13, 2012
eb
4$ on ebay
Can you tell me where you got the Micro USB to Micro USB cable?
4$ on ebay
Most likely from this seller.
http://www.ebay.com.au/sch/m.html?_odkw=&_ssn=yourcharger&_armrs=1&_osacat=0&_from=R40&_trksid=p2046732.m570.l1313.TR0.TRC0.H0.Xotg.TRS0&_nkw=otg&_sacat=0
Makes great little OTG cables, shapes, sizes, connections.
Not good micro usb cable
I had ordered 2 when i got mojo first time many months back..
Penon's micro usb cable is better than this cable !
Geez, you must be pretty rough with them.
I own 3 and they're all fine...
too bad when connecting the AP60 to my E5 via micro usb to micro usb cable, no sound at all coming out from E5 ..
the usb connection mode is USB ..
AP60 recognized the audio connection to E5 when using that micro usb cable, and there I have it, no sound at all
m firmware is 1.01b
It might well be that the cable/adapter you have doesn't support the OTG standard that is required for the data stream to be recognised.
too bad when connecting the AP60 to my E5 via micro usb to micro usb cable, no sound at all coming out from E5 .. the usb connection mode is USB ..
m firmware is 1.01b
but I like the wireless connection from AP60 to E5 .. now I can listen to hi res music and receive incoming calls
I guess my walnut is officially retired.
setting DAC mode (dac/usb)
I know that
why is ap60 down DSD samping rate to 88.1(yellow light in mojo)
many player can play DSD but can send DSD native to usb
give the issue to HIDIZS engineer make on new FW. for fan
DSD native via usb
http://www.sa-cd.net/showthread/83581/83606
