Safeinthemountains
I'll check at home on The R5Gen2 but my "small" R5 is currently running 2.1.5 "Professional Edition". On my smartphone it is running V4.3.3 International; can someone tell me the difference between these two versions ? Because I cannot really see what is different
[EDIT] just back home. I fired up the R5 Gen2 and went straight to the Hiby App. Was not on the latest version, so I was proposed to upgrade to 2.1.5. with a popup.
I launched the update, it took ~1min to download. Then I had another pop-up, probably from ApkPure, that asked me if I want to perform install using "package installer". Then it's done !
So make sure you have Apkpure installed first... When performing upgrade through the Hiby app itself.
