If anyone interested, I do a size comparison between M1S and R2 on M1S thread.
For portability plastic do seems nice as it has less weight, but it does feel cheap even compared to M0 Pro. The wheel, if only they designed it like M0 pro it will be much easier to use single hand.
A bit sad as M1S can actually charge while using it with PC (Mass Storage mode), not sure why they disable it as it doesn't affect much I suppose?I don't have many HP/IEMs with inline remote/mic. I tested the (free) Loki sent with my R2-II as well as an older Fidelio S2 and could not make it work with my iPhone. Same thing with the R2. I believe that, although the R2/R2-II support multiple audio codecs (SBC, AAC, aptX, LDAC, UAT), they haven't implemented the bluetooth HSP, HFP, AD2P and AVRCP profiles needed for cell phone-headset communication (at least support of some of these profiles is needed). I don't have an Android phone, but I suspect it is the same story.
Some observations about the R2-II:
I was reading a review of the Shanling M0 Pro on Heafonics where they say, as a comparison, that the R2-II can't be used while charging. This is somewhat incorrect: you can't use the R2-II if you connect it to a PC USB for charging. In that case, it is seen either as a mass storage or a DAC (configurable in the settings). But if you plug the R2-II onto a regular USB charger or power bank, you can absolutely use it, and have all the functionalities available while charging.
Hiby has added an "Album Artist" option in the Music screen... Great !!!:
.........Except that when I select an "Album Artist", the list of albums from that artist that I was expecting to see next is not there... instead, what I get is a list of all the tracks from that album artist, sorted by album/track number........???..... The "Artist" option is unchanged and does show the list of albums where the selected artist has at least one track. So, with that new "Album Artist" option, IMO the two behaviors should be reversed: 1/ "Artist" > list of "Tracks" from that artist, sorted alphabetically. 2/ "Album Artist" > list of "Albums" for that album artist, sorted alphabetically (or by Year?) > list of "Tracks" for that album, sorted by track number.
The R2-II body is plastic... good quality... but still plastic! A big downgrade from the R2 IMO.
Subjectively, the R2-II appears much bigger than the R2, closer to the R3 than the R2.
The volume pot is an encoder (infinite rotation, 100 "clicks" to step from 0 to max. volume). It is great, but I keep pressing it expecting to turn the screen on & off,, or to get some other menu shortcut. Feels like a missed opportunity.
Edit: Added picture of the "Music" screen.
Also forgot to mention the Wifi: the R2-II has much better reception than the R2, but it is 2.4 Ghz only! The R2 had support for both 2.4 and 5 Ghz.
