http://www.jr.com/audio-plus-services/pe/ASV_JMLXS21/
Integrated USB soundcard / 2x30W for speakers and 70W for subwoofer / Dock for listening and recharging for iPod with a synchronization mode via iTunes
Focal XS Speaker System from Audio Plus services is a high-end audio speaker system for your iPod - or your Macintosh. Connect Focal XS to your Mac through the USB mode and listen to your favorite Music from iTunes with the realism of a Professional monitoring sound: definition, tonal richness, spacialization and power. Charge, sync, and listen to your iPod using the built-in dock. Choose the dock Adapter corresponding to your iPod and control it with the included remote. Switch on the synchro mode at the3 back of the dock and your iPod automatically synchronizes with iTunes. A very simple and real solution of sound monitoring for any multimedia application. Focal XS will satisfy those sound and Video lovers who work with audio Software such as Garage Band and Logic Studio or video applications like iMovie or Final Cut.
Considering the hours you spend storing and listening to iTunes, don't you deserve the best sound delivery? The Focal XS offers clarity and wide dynamic range that pale other speaker systems.
[*] 2.1 Sound delivery system - Left and Right Channel speakers / Subwoofer
[*] High end Multimedia solution with Integrated USB soundcard.
[*] Dock for listening and recharging for iPod with a synchronization mode via iTunes.
[*] Active amplifier, 2x30W for speakers and 70W for subwoofer.
[*] Remote Control of volume and iPod
[*] 3.5mm mini-jack Analog Input for media players of other brands
[*] Jet Black and anodized aluminum finish
[*] Metal support stand
