If you are feeling patient have a read of this and see if you can help stopping me waste hard earned money.
I am in the very fortunate position of having a few hundred pounds to spend.
I am in the unfortunate position of being 58!
My aim is to put together a nice set up to last the rest of my days.
I listen to IEM's most of the time but thought that a home rig would be nice.
I have bought a pair of HD600's which seems like a good start.
Then I started looking into amps.
I had convinced myself that the Lehman Linear was the way forward. Although I suspect that a lot if what I will be paying for is nice build quality.
Then someone suggested that I could get a portable amp that would drive my IEM's when I am out and about. I listen a lot this way.
The Cypherlabs Theorem DAC Amp came up.
This led me into the realms of bypassing the DAC in my iPhone 5s and the possibility of using a balanced output.
I am sceptical of both these options.
I have read on here pretty convincing accounts of all DAC's sounding the same.
Balanced operation is designed to counter problems associated with long cable runs used in pro situations AFAIK.
I am starting to smell BS.
Am I right in thinking that the DAC in the iPhone is fine?
That my Headstage Arrow powers my IE8's just fine?
That a desktop is the best option for the HD600's?
That I do not need balanced outputs?
Thank you Very much for any light in the darkness!
