Blackjackx1031
I have the ZMF Aeolus headphones that im trying to use with the Audeze LCD Boom Microphone cable. I have tested that the sound/mic works plugged in directly into my MOBO with a normal female TRRS to 2 male TRS connector splitter. JDS sells a premium headset adapter for ps5 premium Cable that is essentially a splitter a female TRRS 3.5mm (C) to a male 6.5 mm TRS (A) and 3.5 mm TRRS (B) that would generally connect to a ps5 controller. However it is said that it can be used on pc/smartphone if the pc or smartphone has a CTIA TRRS 3.5mm connector. No motherboard currently supports that and unfortunately when trying anyway a ground loop happens along with the mic not working. So that's not an option. I have read through the documentation for the JDS Element 3 and none of it really helps.
So from there I worked with Hart Audio cables to make a custom cable which is essentially the same Cable as the above with the only difference being B1 is male 3.5 mm TRS instead of a 3.5 mm TRRS. I had the custom cable made and it unfortunately doesn't work. After testing only 1 side work at a time. If they are both plugged in the audio will over ride and the mic will not work. To add i have been in contact with all 3 of the manufacturers customer support and all have been extremely helpful.
I'm at my wits end with all this. Its been a few months of struggling. I know there are probably better ways to go about doing this but they are not an option. I have two people constantly playing in the room so a desktop mic is not feasible. I know there are 2 amp/dacs that have mic inputs but they do not work with the ps5 + i would like to not have to spend even more money.
ZMF Aeolus/ Audeze Mic cable. (https://www.audeze.com/products/lcd...HKOgH8P1uKfBOyvpEDdI-tzLR3KVH9OgaAuDwEALw_wcB)
Confirmed working with a simple Y splitter cable provided by audeze directly to pc
Custom Cable by Hart Audio=
Only 1 end works at a time. If both are plugged in the audio works but not the mic. The only time the mic works is when audio is unplugged
(C) = Female 3.5mm TRRS
(B1) = Male 3.5mm TRS > Motherboard I/O Mic input
(A) = Male 6.3 mm TRS > JDS Element 3 amp/dac > optical to PC
PS5 Premium adapter cable from audeze ( https://jdslabs.com/product/premium-headset-adapter-ps5/)
Causes ground loops + Mic not working. Works on the PS5 though.
(B) = Male 3.5mm TRRS > Motherboard I/O Mic input
- Is there something with the custom cable that would cause this to happen? Being incorrectly wired? Should i try to get another cable made?
- is it something with my JDS Element 3 that is preventing the mic from working?
- The end connector shouldn't matter right as long as the connectors are both TRS the size should be irrelevant right?
