Oya?
- Mar 31, 2008
Hi HF,
I bought a Millet hybrid from here very recently and I want to install a power switch, because it doesn't have one. I've got some tools but absolutely no DIY or electronics experience really (never soldered anything) so I'd really appreciate any help, and apologies in advance for the really newbie questions.
I did a search here so I think I sort-of understand what I need to do, There's a black and a red wire going to the power jack, I'm supposed to desolder the "hot" (red?) wire from the power jack, solder that to one of the two terminals on the switch, and then wire the other terminal back to the positive terminal on the jack?
I bought a SPST rocker switch from a store, it's got two terminals and one's shorter than the other; I don't know if that means anything though.
And I need to drill a hole in the rear end-plate for the switch. Does it need to be a really tight fit? Does it need to be threaded? I've got a stepped drill-bit; if I attach it to a hand-drill I should be able to go through aluminum no problem right?
More importantly though, is there anything else besides the switch that I need to add to the amp itself? Like any resistors or caps or what-not. I looked up the archived parts list and I don't think there's anything important missing, but I can see a few empty/bypassed spaces on the PCB.
Thanks for reading.
Thanks for reading.
