yeky83
- Oct 6, 2010
Hi, people of Head-Fi forums.
I know that this post is way beginner-ish, but I learned to do my first fix here, so I thought I might ask...
I have an old battered shure e4 that I'm trying to fix up.
My first fix: the broken plug.
Through reading these forums, I bought a neutrik plug and replaced the old plug with the weak connection.
But now I found another place with a weak connection...
The only way I can think to fix this weak connection is to just cut away the L-R splitter protector and rewire the cable so that the weak connection is gone. But I'm just wondering, is there a way to save the splitter protector somehow?
Or is there a way to make myself a cable L-R splitter protector?
I don't know what the wires would look like if I cut away the L-R splitter protector... I would think that it's there for a purpose, so just cutting it away is kind of dissatisfying for me.
Also, to fix a potential problem before it happens...
The rubber sleeves that protected the cables from bending excessively has ripped off from long use. Can anyone suggest a way to replace those rubber sleeves?
Thanks!!
Thanks!!
