mesaboogie
I have been around hifi and pro audio but headphones I never got into. I have acquired a pair of Audeze LCD 3 headphones and I am googling the devil out of the impedance matching. I am not seeing a clear understandable explanation of why these (headphones in general) don’t require a match the way speakers do. We should use the impedance of the headphone divided by 25 for the amps output impedance? Mind->blown.
I have built a few tube guitar amps and own a nice hifi tube power amp and that just seems completely counter everything I have ever known.
So question
1) if a company like Woo Audio lists the output at 8-600 ohms, are they saying it’s okay for use with headphones rated between that? Their hi z/lo z switch sets it to two settings that accommodate with approve mismatch anything between there? Would it stand that 8ohm is one of the OT taps, or would it be more likely higher and they say it will work with a 8ohm headphone?
2) from the above, if listing 8-600 ohm, are they saying the headphones actual rating? Or is that for the amps impedance after you do the math of 110/25?
3) LCD 3 is 110ohm. So I want about a 4.4ohm output transformer?
I have heard them with the WA7 fireflies and while the Hiz setting initially sounded more immediate, the loZ setting was more pleasant after a short time. Still trying to determine if I want to buy a tube or SS, or if there is a true audiophile level kit/layout; build my own.
The WA7 with the LCD3 was a hair warm on the top end. Far from bad though. I heard the Focal Utopias thru it though and they have the top end. So maybe part the headphone and a slightly brighter amp is what I need.
So question
