Hey Guys, I recently purchased a PIMETA amplifier from a local friend, but he did not include a PowerSupply unit with it. He did tell me that I needed a powersupply capable of 12v+/-. The OpAmps used in the amp are: ad8620
So I assumed that 12V +/- meant 24v total, so a 24v regulated powersupply should be adequate, correct?
Anyways, after researching what is used most commonly for the PPA (which I wish I had the money for) and other PIMETA amp owners, it seems the Elpac WM080-1950-760 is the most popular. I was told this was because it has a low Ripple Noise of 0.5%.
Now, the problem, when I looked at that specific Elpac model, noticed the specs sheet said it used a 5-pin round type of connector, is that correct?
If so, it would no work with my PIMETA because it has a 2-pin type Barrel connector, meaning it uses one of those pin type things where the outer shroud is negative, and the inner-center pin is positive. After looking at Elpacs models that have this type of connector, they dont offer any 24v powersupplys with the same low 0.5% ripple noise.
Here is a pic of the DC connection port in my PIMETA:
http://www.oldschoolcaraudio.com/pix/pimeta-rear.jpg
My question is, do you guys know of any powersupply with my type of connector that will be high quality?
OR
Should I order one of the 5-pin connectors and attempt to change mine out so I can use that type of powersupply...
ANY HELP would be appreciated, I am a certified NEWBIE (tard) to the headphone hi-fi community, as I have been strictly car audio hi-fi for 10years.
THANKS!
-hybridamp
_________________
TeamROCS Member
http://www.teamrocs.com
OR
THANKS!
-hybridamp
_________________
TeamROCS Member
