Jimbtoo
Hello! I am a new member, just getting back into headphones a bit, and well, you guys are the masters of these issues!
I am the original owner of the 1975 Stax system in the topic title. It has been little used in decades - just sitting in a plastic bag in a cabinet. I need to get back into headphones for a variety of reasons and thought I should at least start with what I used to love so much. This system was my first, truly high-end component, back in 1975. So I fired it up and it sounds limp compared to memories. I have read about rebuilding 'energizers', and the SRD-7, in particular. I noted that the nominal bias is 230V for these, non-Pro, units. Mine measures about 100V from the main bias pin to any of the electrode drive pins. Not good, right? Assuming this is in fact low, there is some failure in the bias circuit. I've also read some great notes about replacement parts for these original components and I am game for replacing/upgrading any or all of them.
I have also just purchased NEW Focal Clear and Utopia headphones (it's complicated). I will be keeping ONE headphone system at the end of all of this. I am evaluating a new Benchmark HPA4 driving the headphones (the alternative is the Benchmark DAC3 HGC, directly). I've not yet tried the Stax on the HPA4, but I suspect it might have sufficient drive range (at least 6W) IF the Stax system was working normally. I am less likely to keep the Stax if it cannot.
Given that background, should I bother messing with the Stax?
a) Is the HPA4 likely to be able to drive it, effectively?
b) Is it ever going to compete with the new Focals?
c) Is there any market for the Stax as-is? I also have a nice, long extension cable for it.
d) Is the resale value after refurbishing it going to be significantly more than as-is?
e) If I refurbish it, would it be appropriate to increase the drive voltage a bit, say 10 or 20%? That would be by using the next higher value diodes in the bias string (up from 100V to 110 or 120). Is that likely to be beneficial? Is it likely to damage the (old) SR-X phones?
Depending on what you all can advise me, I might have a few follow up questions to wrap it all up.
Thanks!
Thanks!
