amitpop
- Nov 24, 2008
Here are the specs from my instruction manual for my Phillips FW-C255. Can someone tell me the sound wattage of the system (and what most of this stuff means)?
Thanks
AMPLIFIER
Output power ...................................... 1500 W PMPO
......................................… 2 x 40 W RMS(1)
Signal-to-noise ratio .......................... ≥ 67 dBA (IEC)
Frequency response .......................... 50 – 15000 Hz
Input sensitivity
AUX/CDR In ........................................… 500 mV / 1V
Microphone ........................................… 3.5 mV
Output
Speakers ........................................… 6 Ω
Headphones ...................................... 32 Ω – 1000 Ω
SPEAKERS
System .................................... double port bass reflex
Impedance ........................................… 6 Ω
Woofer ........................................… 1 x 5 1/4" full range
Dimensions (w x h x d) . 210 x 310 x 235 (mm)
Weight ........................................… 3.1 kg each
GENERAL
Material/finish ........................................… Polystyrene
AC Power
For Version /21-21M .. 110 – 127 / 220 – 240 V;
......................................… 50/60 Hz Switchable
For Version /30 ........................ 230 – 240 V; 50 Hz
Power Consumption
Active ........................................… 70 W
Standby ........................................… < 15 W
Dimensions (w x h x d) ..... 265x 310x 365 (mm)
Weight (without speakers) ................................ 6.4 kg
Thanks
AMPLIFIER
Input sensitivity
Output
SPEAKERS
GENERAL
AC Power
Power Consumption
