rolz
- Nov 23, 2009
anyone ever had an issue with their IE8s constantly losing sound?
my right earpiece has had a progressive problem cutting out for a couple of months now. started with a very slight volume and bass loss. eventually the sound would cut out and i would have to adjust the plastic stem to the earpiece a little and it would be good. but now, i have to constantly push it to make it work. i've already tried reseating the cable to the earpiece a lot of times. my left earpiece would do it once in a while but very rarely.
warranty is out of the question since i got this unboxed. the SQ is as good as ever but this problem just kills it.
any tips for a DIY fix? I'm sure the prob is with the contacts. the cable has this two metal pins on it that connect to the 2 holes on the earpiece. i noticed i can get it to work if i kinda tilted the stem back or forward. it also works if i push it hard to the earpiece. any suggestions would be welcome
