pldelisle
- Mar 28, 2015
Hi all,
I'm having a hard time configuring my Mac. I've just installed a fresh copy of Mac OS X El Capitan 10.11.1. I own the software Audirvana. One thing has always been bugging me : I cannot control the volume uniquely by my amplifier. If I activate the following parameter that should be enabled to get bit-perfect audio playback, the sound is terribly clipping and have a lot of distortion. It is not even listenable.
The only way to correctly listen to music with Audirvana is by selecting the Software Only option and minimizing the volume to -15 dB.
I've also tried another player, Fidelia, which does the same thing. In it, we can have a representation of the file where we clearly see the signal goes beyond 0 dB.
I can only listen to the song via the DIM button. CDs were extracted with XLD with log file 100%. Should not be a problem !
Is there a way in MacOS to get a reasonable signal out of the Mac ? Because I clearly don't see how to get a decent sound with direct volume.
DAC is Schiit Gungnir. Amp is Schiit Asgard 2.
Thank you very much for your help !!!
