sdheda
- Sep 19, 2005
I need help getting my M-audio Transit to work properly.
The current settings I use are 2in, 2out, 16bit, 8000-48000Hz with Latency set at Very High. This setup works fine with ASIO in foobar.
The problem arises when I try to set the output at 0in, 2out, 24bit, 88200-96000Hz with Latency set at Very High. The settings in foobar are 24 bit output, SRC set at 96000 sinc best. At these settings there are audio drops when playing a track. When I first start playing a track it seems fine, and then there are audio drops that just get worse with time. I think that problem is latency, because if I change the latency setting to a lower value in the Transit cp, the drops become more frequent.
I am using foobar 0.8.3 because I am using Mediaportal on a HTPC and their plugin only works with 0.8.3.
Any suggestions how I can solve this problem.
I also have a question to all the people that are using the transit in 24/96 mode. Are you still able to play movies, etc. in this mode without any problems?
Thanks in advance.
Thanks in advance.
